Hi Everybody,
I try to export an IFC that contains every view that I can find ( or that I have created) from the treeview of REVIT.
The main goal is to open my IFC with others soft such as Solibri, and be able to find all my standard views, instead of just having a global 3D view.
Thank you a lot in advance for your advices.
Grégory Hilger
I am quite sure this will not work on ifc, but you can achieve same thing if you open native Revit file using Navisworks Manage - not sure if that fits your needs though
I see that you are a new visitor. Welcome to the Autodesk community!![]()
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.Kudos welcome.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
