Is there a way to define the dwg Linescale of an export from Revit? of
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
infoWBN4V
376 Aufrufe, 3 Antworten
Hi everyone.
I am tesing dwg exports from Revit which include detail lines with certain patterns.
While the patterns in Revit show accordingly to the pattern definition (i.e. dash 2.5 mm + space 2.5mm), every time that I export a 2Dview to dwg I have to change the linetypescale to 50 in order to make it look in Autocad exactly as in Revit.
I don't think it's a matter of file units since the newly created dwg file has the same units than the revit project (meters).
Obviously I would like to avoid having to open each dwg and change the linetype scale.
Any solution will be more than welcome.
Thanks so much.
3 ANTWORTEN 3
Nachricht 2 von 4
benschilders
als Antwort auf: infoWBN4V
You could try to change this setting:
1. click on this ... to open Modify DWG/DXF Export Setup
2. Under the tab Lines you can set a linetype scale setting
What it should mean:
  • Scaled Linetype definitions. This option exports linetypes the same as they were previously scaled by view scale. This option preserves graphical intent.
  • Modelspace (PSLTSCALE = 0). This option specifies the LTSCALE parameter to view scale and the PSLTSCALE to 0.
  • Paperspace (PSLTSCALE = 1). This option specifies the value 1 for both LTSCALE and PSLTSCALE. Revit Architecture linetype definitions are scaled to reflect project units, but otherwise they are exported as is.
Source:
https://gtu.ge/Arch/Faculty/Multimedia/Resources/Revit/Help/filesUsersGuide/WS1a9193826455f5ff104d7f...
Never used it myself in practice but this should work.
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Nachricht 3 von 4
infoWBN4V
als Antwort auf: benschilders
Awesome.
Nachricht 4 von 4
benschilders
You are welcome always fun to help others and learn something at the same time !
