- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone.
I am tesing dwg exports from Revit which include detail lines with certain patterns.
While the patterns in Revit show accordingly to the pattern definition (i.e. dash 2.5 mm + space 2.5mm), every time that I export a 2Dview to dwg I have to change the linetypescale to 50 in order to make it look in Autocad exactly as in Revit.
I don't think it's a matter of file units since the newly created dwg file has the same units than the revit project (meters).
Obviously I would like to avoid having to open each dwg and change the linetype scale.
Any solution will be more than welcome.
Thanks so much.
