I have created a stringer in a generic family. It should have some parametric holes on it where there are steps. For defining a parameter for the number of holes, I had to create an array of them. It also has to have a parameter for the distance between the holes. As I can not align the arrayed holes to the work planes I can not create these holes in the same family. The only solution I could come up with was creating one set of holes (voids) in a separate family and loading them into the stringer family. But when I do that it does not cut the extrusion.
Gelöst! Gehe zur Lösung
Gelöst von ivy_moghaddam. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Load both of these families into a project and cut the void in the project. I hope it will solve.
Why not to create the voids in the same family of the stringer and create the parametric relations there?
I tried to create an array of voids but it did not work. My problem is that I can not align and lock arrayed voids to a work plane to define a parameter for distance between them.
Thanks for your answer. I tried this but unfortunately it did not work. The problem is still there.
Create a void in a face based family, cut the host with it. Nest it in another face based family, array and setup spacing parameter. Nest this second family to your stringer family and associate spacing parameters.
