Is there a way to cut an element in a linked revit model yet?
fouad.ouahil
Message 1 of 8
fouad.ouahil
Hi All, just like my question is in the subject, has this been added to revit since 2022? (the date I didn't use revit extensively😁
Thanks|
Replies (7)
Message 2 of 8
What's the element?
If you are able to Copy/Monitor it, then perhaps you can cut it.  What about that?  Probably a smarter workflow anyways -- assuming the Link Project will need to be updated to reflect the modification to the element.
Message 3 of 8
fouad.ouahil
##- Please type your reply above this line -#
Thank you, I will try that. Although I am not sure if I am allowed to copy monitor elements which will make the model a lot bigger therefore slower...
Appreciate the Idea and will get back to you
Message 4 of 8
RobRocks
What kind of element?
Message 5 of 8
vitorbortoncello
No, link elements are not directly editable. You still need to bring them into your model for editing by using methods such as copy/monitor, binding links, or simply copying and pasting.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 6 of 8
fouad.ouahil
Sorry didn't see your question, yes the element is a wall category
Message 7 of 8
fouad.ouahil
It is a wall
Message 8 of 8
fouad.ouahil
Thank you, I ended up working on the link for cutting manually those openings...long but no choice
