Is there a way to control the depth from which <Beyond> line style will display?
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
PedroAndruccioli
492 Aufrufe, 7 Antworten
Really simple question, but I never found the answer. Here's an image (in centimeters):
From Revit's logic, the beyond line style should display from -1 onward, but it is only shown from -122 below. Is there a way to control this?
Thanks.
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: PedroAndruccioli
How did you apply the Line Style? Via Linework Tool?
Nachricht 3 von 8
ralphdenhaan
This is hardcoded in Revit to approximately 1.22m: View-Depth-Display
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 4 von 8
PedroAndruccioli
als Antwort auf: barthbradley
Just the View Range settings, no manual work or override.
Nachricht 5 von 8
Floors will show normally within 4' (~1.22 m) of the bottom of the view range.  If you want to show a floor within 4' as Beyond then convert it to Parts, or use Slab instead of Floor.
Nachricht 6 von 8
PedroAndruccioli
als Antwort auf: ralphdenhaan
I see. The same "logic" of not cutting walls that are less than 200cm high.
Do you or @ToanDN know if there is any standard in which they based these rules, or if they are random?
Nachricht 7 von 8
Nachricht 8 von 8
I guess the decision was based on the drafting graphic standards to show stairs extending up to 4' below the level.  It doesn't translate well for the display of stairs below in Revit and it doesn't make much sense for floors and ramps.
