We use wall centerline for SF calcs / dimensions as our default.
On a mixed-use project that's well into design, the client just decided they want the drawings to show usable SF instead of centerline calc.
Is there an automated way to change from centerline to finish wall across the model, and update the dimensions? (don't really have the time to do it one unit at a time). I've been told that once the perimeter lines are set in the beginning, they have to be adjusted manually, which seems silly.
Gelöst! Gehe zur Lösung
Gelöst von broderickwhitlock. Gehe zur Lösung
You can set the room to wall center under Room & Area setting
For dimension, you may want to check out Evolvelab Glyph
https://www.evolvelab.io/glyph
Ok - this is what I'm hearing. Changing the line location doesn't update the dimensions on the drawings. I'll look at Glyph, thanks.
Correct, you could leverage entire wall for the measurements once you make the change to finish face or int. face of core to speed up the process a bit.
