Is there a way to alter the grid line length in one view without affecting the other views. I often face problems when placing views in sheets as sometimes the scales vary , and the grid lines often go beyond the boundary of the sheets . But when i pull the grid length short , it also shortens in other views too
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
This is where scopebox become handy. You can use scopebox to control the view and this will also control the grid crops. Also watchout that you don't drag 3d grid grip. Always click on 3d to 2d and then drag the grid grip. Most often people move the 3d grid grip and it makes you grid display all over the place.
Thank you...just gonna leave the accept solution just to see if others have a solution too...will accept it later..also viewd and subbed your youtube channel
maybe you can refer to article some explanations and see if helps. thanks
it takes practice, What you need to be hyper-aware of is the teeny tiny "2D" and "3D" labels, and teeny tiny Open Circle and Solid Dot visual clues. Definitely prescription eyewear is a must. Can't expect to look "cool" to the cute receptionist while managing your grids. It's a nerdy exercise to say the least. Do it in private.
@chhuanmawia18 wrote:Thank you...just gonna leave the accept solution just to see if others have a solution too...will accept it later..also viewd and subbed your youtube channel
You don't need to ration out solution credits. Give the man a pat on the back with a solution credit. Scope Boxes is a great suggestion. Had you thought of it? Well, now you have.
