I'm looking for a quick way to rename a number of grids to avoid having to manually re-name them, similar to auto-number in autocad.
I found an app but it hasn't been updated since Revit 2019 and I am on Revit 2023.
https://apps.autodesk.com/RVT/en/Detail/Index?id=3264579464296250811&appLang=en&os=Win64
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You can use dynamo. Check this video to show how to create and rename grids
https://www.youtube.com/watch?v=JbChOKy8H1c&ab_channel=ArchgyanRevit
I would recommend pyRevit. it has a renumbering feature and a lot more besides.
Thanks everyone! I will try out pyrevit! Thanks for including screenshots on where to find it once i get it installed!
Maybe someday Revit will implement renaming grids into the program itself ![]()
