Is there a calculator in revit?
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
emmanuelbee
4563 Aufrufe, 8 Antworten
is there a way to make quick calculations of numbers etc in revit rather than always having to open the windows calculator app for calculations ?
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: emmanuelbee
You can enter a formula directly in a dimension string, for an instance.
Nachricht 3 von 9
You can totally do long addition too....so 8+6+7+5+3+0+9 will give you 39. :Gesicht_mit_Zunge:
Nachricht 4 von 9
...oops
Nachricht 5 von 9
ccastelein
als Antwort auf: barthbradley
didnt answer the question to original post... does it have a calculator...
like how many 18" in 200'
Nachricht 6 von 9
als Antwort auf: ccastelein
=200' /18" when modifying a dimension...
If you are looking for a little calculator button that pops up a calculator like in Windows, then no, it doesn't have one.  Keep a shortcut in your taskbar if  you need a separate calculator app.
Nachricht 7 von 9
=round(200'-0"/1'-6")
Smiley (zwinkernd)
Nachricht 8 von 9
ccastelein
i wasnt trying to put in any dimension i just want to know/or calculate a feet and inches question... basic windows calculator (to my knowledge) doesn't do feet and inches, and the free calculator from windows, that does, kinda sucks. Acads works nicely... thought autodesk would put it in revit, seems it would be easy to do..
Nachricht 9 von 9
I'm sure someone can do better....but this took a minute or two...
Oh...and Autocad is a totally different UI than Revit.  So if Revit was to have a calculator button it would probably just popup the Windows version.
