Is possible to really import an image to a Revit File?
4 ANTWORTEN 4
Nachricht 1 von 5
lucas.portoDB4QW
2441 Aufrufe, 4 Antworten
When we use Insert\Import\Import Image to insert an image on a family or a project and later open Manage Links\Images, Revit always shows that this image is a Link with absolute path. There is any way to really import images to Revit files to keep then embedded to the files?
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
If you import an image it will be embedded in the Revit project file. Even though it is in the manage links menu you will see it is set as an import
You can ignore the path, that's really meant if you want to substitute the image
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 3 von 5
benschilders
als Antwort auf: lucas.portoDB4QW
i believe you should try this option " Import image"
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Nachricht 4 von 5
No. But if you want to share everything in one submittal, maybe using eTransmit would be the way to go.
Nachricht 5 von 5
If you use Import, not Link, then the raster images or PDFs reside in your Revit file.  You can remove/rename the original images or PDFs and they still show in Revit.  You just cannot update them without pointing to the new file locations.
