Is my link not linked correctly?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
s152732
580 Aufrufe, 2 Antworten
Hi.
I am doing a project at my university. I have noticed in the project browser in Revit under "Revit Links" that one of my linked models has a red X. I do not gen any errors when I work in the model - But does that mean, that I will run into problems later on in my project?
Heres a picture of it.
Have a nice day.
Pernille
2 ANTWORTEN 2
Nachricht 2 von 3
mauricio_mssf
als Antwort auf: s152732
This red x, means that there is a link, but it's not loaded in this moment.
Check your manage nenu or click with your mouse right button on the link on the project browser and try to reload.
If you have the file you can load or relaod whenever you want. don't change the name and keep in the sane path.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 3 von 3
s152732
als Antwort auf: mauricio_mssf
It was really helpful - it worked. Thanks for a good explanation @mauricio_mssf !
