Is it possible to use .fbx files in Autodesk Revit?
5 ANTWORTEN 5
Nachricht 1 von 6
3523 Aufrufe, 5 Antworten
Basically the question above. I am attempting to use a .fbx file from Esri CityEngine in conjunction with Revit to do some landscaping, and I am wondering if its possible to import a topographic scene from CE into so I can build on top of it.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Import FBX into 3DS Max and export it out of Max as a DWG  -- and then bring the DWG into Revit.
Nachricht 3 von 6
You can also open it in AutoCAD and save it as a DWG.
Nachricht 4 von 6
Only in AutoCAD 2018 or earlier can you Import FBX. Went away in 2019.
FWIW.
Nachricht 5 von 6
als Antwort auf: barthbradley
Yes you are correct - can't do it after 2018.  Thanks for that.
Nachricht 6 von 6
Thanks. Just as a follow up, would I be able to edit .fbx file in the revit workspace? Since its loading in as a CAD file, I'm worried it wouldn't have the 3d elements I need. Personally, I have little experience with .dwg files, and I just want to ensure I have the proper workflow.
Cheers!
