Is it possible to turn area plan to a regular floor plan? (omitting the area plan title/ definitiion)
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Well, with Revit, you can create as many new floor plans as needed. Just go to View > Floor Plans > do not duplicate existing views, and select what type of plan(s) view(s) you want to create. It's just a few clicks.
It's not clear why you want to "turn area plan into a regular floor plan", or what that means.
Thank you for your reply
I deleted some regular floor plans and duplicates an area plan to my regular floor plans.
My question is how to convert area plan as such to a floor plan.
I know One can create new floor plans.
thanks again,
efrat
It's the same question, so I have the same answer as above.
I would turn off the area object and area boundary. Then it will be just another regular floorplan.
A type of view cannot be "turned" into another type. Why don't you simply create a new floor plan?
