Is it possible to rotate a section in the diverse direction?
I want to rotate a section aligned with the flat surface, which inclined in 2 direction of xy and yz plane. But ever I rotate the section in plane view, it became invisible in originally pararell view, lead to make second rotation impossible. How can I get the section pararell to a slanted plane, or is it impossible without doubt?
Diogo_Nery
If it's sweep modeling, you could try to draw in the 3d view, because there you could use the "select path" and click on the faces you want.
Diogo H. Nery
q
Oh, I just want to know about the section. The model was already completed. thanks
Rotate in plan view. Create another section view perpendicular to the rotated section line. Open it and rotate the section line in that view.
