Is it possible to make a roof opening cut part of any option?
6 ANTWORTEN 6
Nachricht 1 von 7
svalente9GJKH
340 Aufrufe, 6 Antworten
i want to make an optional dormer on a home.
I am trying to make the roof cut opening part of my dormer option, but this doesn't seem to work?
What's the best way to do this?  Will i need to create a whole separate roof? of creat an infill peice of roof and have it turned off on the dormer option?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: svalente9GJKH
Don't know why dormer wouldn't work. Post the File here. Or, maybe a screenshot will clue us in on the issue.
Nachricht 3 von 7
svalente9GJKH
als Antwort auf: barthbradley
getting this result for my dormer cut option.  should it be possible to add the roof cut to the option
that can be turned off?
Nachricht 4 von 7
GustavoUbriaco
Hi!
Yes it's possible only the dormer have to be the 2nd option, forget the next steps.... LOL I understood bad
Step 1
create roofs and walls to get the dormer attach the wall top and base to the roofs
Step 1.1 to attach the roofs use this tool
Select the border of the roof to attach then the roof target
Step 3
To realize the dormer In the arch tab, opening panel, use dormer
Select the roof to be cutted and then select walls and the roof who intersects, here I isolate the parts that I needed, then set wireframe to see the interior wall faces
Use trim to make corners and now you have a perfect dormer
Gustavo Ubriaco Contreras
Nachricht 5 von 7
Sorry. Not following you. Got pictures?
Nachricht 6 von 7
You need to keep a Main Roof, its Opening, and a Dormer in each Design Option.  So basically you will need to duplicate the Main Roof for all the Options.
Nachricht 7 von 7
als Antwort auf: ToanDN
LMAO!  "DESIGN"!!! That one f'ing word make everything @svalente9GJKH said totally understandable now.  Yes, hosted elements without the host element cannot be added to a DESIGN Option.
