Is it possible to input the exact height of a crop view in 3D ?
2 ANTWORTEN 2
Nachricht 1 von 3
jsanders
574 Aufrufe, 2 Antworten
Hello, I want to click on the top arrow and put it at +3.00m.
Is this possible ?
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: jsanders
You can eyeball pretty close. Probably get it to within a gnat's eyebrow of the target.
Nachricht 3 von 3
constantin.stroescu
you can do it by making the following steps:
  • in an Elevation view create one or more named Reference Plane(s) at the desired elevation.
  • create one or more horizontal Section Line(s) - ( first vertical then rotate) aligned with the named Reference Planes
  • then, go in the 3d section box View ,  and Right click on the View Cube > Orient to View >Sections - choose the previous created sections and the box , now is cut at the desired level
  • you ca also orient to a Floor Plan but you have to take in consideration the View Range Cut Plane elavation
Constantin Stroescu
