I understand that curtain walls produce a reflection because they are glass. I was wondering if there was anyway to turn that off. I tried going into the properties panel, it said it was structural and would not let me alter the glass material. Any help on this would be great.
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
hello, set the reflectance to 0 see screenshot. thanks
Use the Tab key to select a Curtain Panel in the curtain wall.
Then, under properties, see what material is assigned to the curtain panel, such as "glazing".
Then under Manage tab, go to Materials and change the reflectance properties of the glazing material.
