Dear Forum
Is it possible to create schedules using rooms from a linked project?
I only ask because, in my projects, I can detect rooms from a linked project using a room tag from my host project, but I seem to be unable to use these rooms to make my own schedules within my host project. To make my own schedule I then have to insert my own room family and then re-type the Architects ref number into that. This doesn't feel right to me.
Hope this query makes sense.
Many thanks
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Hmmm thanx fir the response, could you or anyone elucidate? Don't I get to select what elements I can borrow from other links? Or do I just get the lot?
When you select Use From Links, then all parameters from the file and the links are displayed in the left pane. You would select what you need and click the green arrow to move your selections to the right pane.
Items in your model will need rooms or spaces in your model as well. So the method you are using currently is correct. There is an add-in though that will grab all the architect's rooms and convert over to spaces. You would just have to create space schedules instead of room.
What's the add-in to convert rooms to spaces? Sounds like an ugly hack though...
If you don't want extra spaces in the model, there's another addin called RV RoomLink which associates Revit elements in your main model to rooms in link. Just google it.
I did tried that space-copying addin before but also can't remember its name now.
