Is it possible to create a void in wall sweep?
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
7611 Aufrufe, 5 Antworten
I want to create a void in a wall sweep that's placed on top of normal wall. I've tried some generic objects for cutting normal walls and a model-in-place component with a void form but none of these options works.
Is it possible to create a void in a wall sweep?
Tags (2)
5 ANTWORTEN 5
Nachricht 2 von 6
martijn_pater
als Antwort auf: Anonymous
If you create a void in-place, you do have to cut the geometry before finishing the model within the in-place editor.
Wait you meant cutting just the sweep... that changes things somewhat I think, perhaps model the sweep in-place (or as family) also?
Nachricht 3 von 6
RDAOU
I would use a "void in a face based family" or a line based with both sweep and voids... which one can load and cut with.
If you modeled the sweep using In-Place then you would need to model both Sweep and Void within the same In-Place and use Cut before you finish the In-Place element.
- Start In-place component
- create sweep and finish it
- do not finish In-place component
- create void extrusion and finish it
- use cut
- Finish In-place component
Nachricht 4 von 6
als Antwort auf: martijn_pater
Yes, exactly, I'm just trying to cut the sweep.
Do you mean that I should try a different approach altogether, and maybe not integrate the sweep in the wall to begin with?
Nachricht 5 von 6
martijn_pater
Yes, that's probably the way to go. See above by @RDAOU
Nachricht 6 von 6
als Antwort auf: RDAOU
Thank you!
This works, maybe it was my original approach that hindered me. I wanted a default sweep when placing the wall but that sweep wasn't possible to modify to my liking.
