Is it possible to add an additional texture to wood siding in render view?
GMasis001
GMasis001
Perhaps an opaque texture that can show the wood siding similar the image below. I have the siding in the model but no 'wave' pattern shown in the render. I want to add the waves as paint of some sort in the model to show in rendered exterior elevations.sample.jpg
RDAOU
@GMasis001
You would need to generate those waves in a post editing tool or render it in a differnet application which handles material mapping slightly better than revit
Alternatively, you can also generate the image with the waves for the eintire wall and use that in the appearance settings. Not sure how crips the quality will be considering the image size/dimensions, thats why I think post editing such scenarios is more practicale (personal opinion) many hate post editing and try to avoid it by all means
GMasis001
Yes, I edited the sheet in illustrator. Now I have a file set up for just that sheet.
