Is it possible to add a new currency format in this unit (say QAR)?
BalajiHTI
BalajiHTI
L.Maas
That list is fixed. What you could do is add a project parameter (price unit) and add that to all relevant families.
In Revit 2017 you also have the combine parameter where you can then add the two parameters together in one field.
However than you can not use calculations (to show totals).
Louis
Please mention Revit version, especially when uploading Revit files.
kamaluddin.shaikh9
please can you explain me in brief how you got this calculation of the price total
Thank you.
Sahay_R
The Price Total was calculated by a Calculated Parameter
When you click on the highlighted button, it will give you a dialog box where you can create a new parameter and set up a formula to calculate values.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Cucu_Setiawan
I have changed the windows settings, but nothing has changed.
At this time Revit cannot support this section.
Please explain more,
i have also this problem
