Is it possible that Revit 2023 can't do this simple procedure with text parameters?
1 ANTWORT 1
Nachricht 1 von 2
hammadhk
163 Aufrufe, 1 Antwort
I have instances of an assembly that have location codes as instance parameters. I want them to appear like Panel No in the above table, not like how they appear in my schedule currently (below), i.e. in a single text field. this is because in some cases i might have 20-30 instances, and i'd prefer to not have each instance as a separate row. is this possible?
1 ANTWORT 1
Nachricht 2 von 2
emmanoelneri
als Antwort auf: hammadhk
Unfortunatly, I think it's not possible. I also have tried it before.
But you my try to create an auxiliar parameter (SHARED PARAMETER) and try to set it up from the information of all your panel codes. To automate you may create a dynamo routine.
