I am designing a coffee table that is definitely one of a kind. The top will be cantilevered at a ⅓ of the total length, supported by the arm of a saguaro cactus. Is it possible to have revit calculate the amount of force it will take to keep the end of the table from falling over if under 30 lbs are put on it? I would appreciate any ideas as far as what to use as well. I'm thinking about setting some lag bolts into the bottom of the arm and setting it in a 4"X10"X16" block of concrete that would be wrapped in saguaro lumber.
Revit doesn't do structural calculations. Engineers need to bring their Revit model into Robot to do them, not thar I am suggesting to do it for this exercise.
You have the load, the cantilever length, so it isn't terribly hard to figure out the required base and anchors to resist uplifting.
What would be "terribly hard to figure out", is how much load the catcus limb could handle before it got squashed.
