Is it impossible to show linked file as an underlay?
3 ANTWORTEN 3
Nachricht 1 von 4
blank...
170 Aufrufe, 3 Antworten
I can't get the link to show with underlay. It's turned on in VG.
3 ANTWORTEN 3
Nachricht 2 von 4
vitorbortoncello
als Antwort auf: blank...
adjust the view range to achieve a similar effect
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 4
Nachricht 4 von 4
blank...
als Antwort auf: vitorbortoncello
Doesn't really work in this case.
I solved it by creating another view and overlaying it on sheet. I hate that "solution".
@barthbradley wrote:
Change Link/Categories to Custom.
Not sure I can use that in this case. It's the same link I'm working on, not a different link. I'm doing plumbing and have linked model, current view settings and view range are the ones I need and it looks how it's supposed to look. But then I need to overlay a level above, greyed out.
