Is it best to do framing plans with 2d detail componants?
5 ANTWORTEN 5
Nachricht 1 von 6
svalen
474 Aufrufe, 5 Antworten
I have heard most people do wood light framing plans for residential construction
with 2d detail lines/components.  Would you agree this is the most practical way
of doing framing plans?  (I have Revit LT and cannot get a wood framing add in)
5 ANTWORTEN 5
Nachricht 2 von 6
constantin.stroescu
als Antwort auf: svalen
  • If you do not need to extract material quantities and you need it only for graphic purposes in 2d Views ( Plan and Section Views) then using Repeating Detail Component ( Annotate>Detail Component>Repeating Detail Component) is a good and quick choice as long as Revit LT can not use Addins.
  • If you need material quantities lists and  3d Model , then you can use  Columns and Beams or/and Beam System.
  • you can also use Curtain Walls with Empty Panels placed inside the Wall core.....or you can use , simple Curtain Walls with Solid Panels...
Constantin Stroescu
Nachricht 3 von 6
You are probably hearing that from CAD people - not BIM people. If that were true, Revit wouldn't exist.
Nachricht 4 von 6
svalen
als Antwort auf: barthbradley
Ah, I see your line of thinking here...makes sense
Nachricht 5 von 6
constantin.stroescu
I made a screencast in which you can see how behaves:
  • the Repeating Detail Component , that is visible only in 2d Views
  • and the 3 d model of the wooden framing , made by using a Curtain Wall with Empty Panels - this is visible both in 3d and 2d views. You can extract material quantities with this method as long as the mullions are seen as wooden linear elements.
https://knowledge.autodesk.com/community/screencast/5fca75ee-1708-48d7-ab66-486dc667aa2b
Constantin Stroescu
Nachricht 6 von 6
svalen
als Antwort auf: constantin.stroescu
Thanks I will definitely give this method a try.
