I have size of my project layout but no dimensions, Like (in CW) 73' x 63'6" x 78' x 66'. at this stage we cannot check the exact dimensions, so I need to design first layout as it is. When I change 1 dimension or length of a wall the other length change automatically.
How can I design layout of this irregular shape with exact length of walls but forget about angle?
Can you show us a picture of what you want to achieve?
Please see attached.
I want to change the dimensions of walls not the length of wall.
I apologize that I was unable to explain.
in a new file I have created just 1 wall.
Now I want to change the angle of this wall. look the the floor plan from top and change the angle of wall.
See attached.
Let me explain the original problem.
I have created a floor plan. Boundary of my site is 73' x 66' x 78' 63'6".
This will NOT be a parallelogram but it is Rectangle.
At this point I am not sure any of the outer boundary angle.
When I draw a sample outline somehow and complete rectangle it do not allow me to change the angle, If I try to do something it modify length of the wall.
What will happen when I have real sizes and angles?
Do I have recreate the plan?
How Revit allow me to change the angle of the walls?
1. Draw simple shape using 2d ( detail ) lines
2. Finalise the shape...
3 create wall using pick lines and pick those detail lines to create wall
4. When you select a wall, edge point ( blue ) a small movement or change doesn’t allow.. you need to use “ snap “ “ near “ shortcut is “ SN “ and pick a new point to move one edge of the wall...
try and let us know..
cheers
