I want to draw a stair case like the attached one. Can anyone let me know how can I?
Gelöst! Gehe zur Lösung
Gelöst von Kimtaurus. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Create it in Stair by Sketch and draw the boundary lines and riser lines.
Green are boundary lines, black is riser lines. Break the boundary lines at landing as shown.
When you use "Stair By Sketch" you actually lose some functunality for your stairs (tread number, stair path).
I'd suggest using "Stair By component" and then use "By Sketch.It works the same as Stair By Sketch, but you can add a stair run.
