Invisible placed Room Revit 2017
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1365 Aufrufe, 4 Antworten
Good morning, everyone. I have a problem with rooms in my revit model. Some Rooms (and rooms tag), don't appear on any levels or sections but they are properly listed into the room schedule. No rooms were hided, and the offset parameter was the same for every room. Even if I search them from the room schedule (Highlight in Model) I can't find them. How can I solve the problem?
Thank you.
Tags (2)
4 ANTWORTEN 4
Nachricht 2 von 5
zemeraloni
als Antwort auf: Anonymous
Hi @Anonymous
Your model is in spanish so i'm not sure but mabe it related to phasing?
try change the current phase of a view and maybe the room will pop up..
Nachricht 3 von 5
als Antwort auf: zemeraloni
Thank you for your help. I've tried change project phases but it doesn't work, unfortunately
Nachricht 4 von 5
zemeraloni
Did you try delete the room from schedual and insert new room instead?
Nachricht 5 von 5
