Invisible of stair tread and riser number in section
4 ANTWORTEN 4
Nachricht 1 von 5
1910 Aufrufe, 4 Antworten
I could n't able to get the tread and riser number(annotation) for the stair in section. Even i have controlled visibility graphics I can't get it.. Although  I can able to see that dotted line but number I can't. Can you give the solution for this one. (Is it graphical issue..?)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
When you select the dotted line, what do you see on the properties?
Nachricht 3 von 5
als Antwort auf: ToanDN
Nachricht 4 von 5
maxx.blake
We've found the same problem, with no solution.
I've found the cause however - when we "split segment" our section line the Tread Numbers become invisible.
When revert the section line to be straight, the numbers re-appear... It seems to be independant to the stair geoemtry, as some stairs show their tread numbers, and others don't.
Stair Section, straight:
Stair Section, Split:
Smells like a bug?
Nachricht 5 von 5
Hegmannlars
Hi having similar issues. In section and plan.
works for some stairs, doesnt work for others.
