Hi all
Im using an invisible line to hide the transition in floor material on this job - timber floor to kitchen, concrete floor to dining/family. As shown on the screenshots, the appearance on the print preview hides the line using invisible line however when printed it still shows up. Any solutions is appreciat
ed. Thanks
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
still appearing on the print version. Ive also tried changing the setting between raster and vector but that didnt work either.
Are you using the Linework Tool to make the floor line work Invisible or are you using a Masking Region with an Invisible boundary line to hide the floor line work?
I used the linework tool, however because the line runs through the top stair riser it also hid that. So I tried drawing a detail line (invisible) over the line I wanted hidden but still didnt work.
I've just drawn a very thin masked region over the line I want hidden and that seems to have worked.
Just not sure why the invisible line isn't working because Ive used it before no problems.
@Anonymous wrote:So I tried drawing a detail line (invisible) over the line I wanted hidden but still didnt work.
The Invisible Line is probably not working because it is thinner than the Line it is covering.
...betcha the line shows when Thin Lines is turned OFF and doesn't show when Thin Lines is turned ON.
thanks.
I made another invisible linetype - line weight of 5. Tried it again and it worked!
