Invisible faces and floating faces in terrain with building pad
3 ANTWORTEN 3
Nachricht 1 von 4
brunoc_schreiber
684 Aufrufe, 3 Antworten
Hello everyone, this is my first post here! Sorry if I'm posting in the wrong place.
I having some problems using building pads here with my project. It's creating some floating faces and hiding some, see the image below. Does anyone know how to solve this problem?
Building pad problem
Thank you all,
Bruno Schreiber
Bruno Schreiber
3 ANTWORTEN 3
Nachricht 2 von 4
sureshchotrani
als Antwort auf: brunoc_schreiber
In options window try playing with graphics mode, checking & unchecking
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Nachricht 3 von 4
nikijtd
als Antwort auf: sureshchotrani
Hello 2015! I have a solution to your "floating faces" but not your missing faces
When making a curved pad Revit takes the curved line you made and splits it into tiny segments.
It creates tiny faces (actually tiny triangular sections of topo) because the curved lines for each pad have been split differently.
I made the white pad using pick line off the grey pad, so the lines are assumed to be the same, but they're not
SOLUTION: Instead of using pick line to make your second pad Ctrl Copy the exact pink line you used to make the first pad. Paste to same place and trim when you have started making the new pad.
This works for me
Nachricht 4 von 4
