I would like to know, if it's possible to use dimensions with intersecting, grids elements, extents or mid points of elements in model on an automatic way, similar to those when we do on plan view with wall dimensioning. It is very easy and expedient and saves time, on the other hand when I do it on sections or elevations I have to go through all the elements that want the dimensions which inefficient and time consuming , isn't there an easy and efficient way to that?
FWIW: Dimensions can be Copied between Views (via Clipboard Copy - Paste Aligned to Same Place).
It was good to learn that there was feature like to copy and align it to same place, I didn't know that. But what actually I was looking for was any solution or workaround to add dimensions with line intersection, e.g. similar to Advance Concrete where we have opportunity to place dimensions with intersection of grid lines and elements, bcoz this is the most time consuming task for me.
Happy to hear that I could provide some assistance, but regarding the gist of what you are asking: I'm a little lost. Are you talking about automatic aligned dimensions?
How would you go with the following automatic dimension from the elevation view, I'd like to be done at one click as we do on plan view and everything is arranged automatically openings, doors, grids, windows etc.. But in elevation this doesn't happen and I have to click each edge of windows, doors, openings etc..
