Internal Origin
Internal Origin
JGuliker
Internal Origin
JGuliker
Is there a way to turn of the Internal Origin in all views with a couple clicks without the need to go through all +/- 200 views individually?
SteveKStafford
Other than via View Templates...not native to Revit.
Possibly via Dynamo (API) graph but I don't have access to 2020.2 at the moment to try.
Steve Stafford
afshin.bariMP9G6
We've been using view templates ourselves, bit more than a couple of clicks, but unfortunately is the only workaround we know. I'm sure the next update will sort this.
PavelAnd
Hi @JGuliker , try this dyn file.
Best regards, Pavel Plotitsyn.
s.borello
No, I just create a quick view template to achieve this.
m.shcheblykin
If you want to see the origin of some Revit project file everywhere
Just place with dynamo any 3D object with Node Family Instance by Point.
In Dynamo you can find the Node Origin Point which will give the point of origin.
Create a Generic model family  (Solid ball or a cross with model lines) and place it. So you will see the origin everywhere .
Cheers
SteveKStafford
Revit 2020.2 introduced a new sub-category called Internal Origin to the Site Category. All the threads with this subject are concerned with turning it off. We find it is turned on when a 2020 project file is open in Revit 2020.2. It doesn't affect files that are upgraded from an earlier version.
Steve Stafford
