Internal origin lies 500mm over Survey Point
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
pbergkv
429 Aufrufe, 1 Antwort
I have  an issue where Project base point and Internal origin lies 500mm over Survey point.
I can move Survay point so its located at the same elevation as internal origin and project base point, but when i use "specify coordinates at point tool" it still says that my new 0,0,0 location is elevated at 500mm above.
Anyone know how to fix this issue? Or is the internal origin suppose to be located 500mm above shared coordinate?
1 ANTWORT 1
Nachricht 2 von 2
Lance.Coffey
als Antwort auf: pbergkv
Thank you for the question, and welcome to the Autodesk forums!
When moving the Survey Point, make sure that it is Clipped Clipped.png and not Unclipped Unclipped.png.
Moving the Survey Point when unclipped doesn’t change the coordinates, just moves the position of the point.
Lance Coffey
Technical Support Specialist
