Interlock material edges?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
anarie
785 Aufrufe, 6 Antworten
I'm trying to make a material to represent a Sicis domes glass tile. This is an oval-shaped tile. How do you interlock material sample edges so that one blends into the other when it is tiled, and not get gaps between tiles?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: anarie
If you are talking about a rendering image to tile? I wouldn't tile an image of a individual glass tile or bead. I'd find an image representing a square foot or two of the mosaic pattern you want, and tile that image. Or do I misunderstand?
for example:
Nachricht 3 von 7
...I'll add that this will usually require some Photoshopping (i.e. cropping, blurring, etc.) if you want the image to tile seamlessly.
Nachricht 4 von 7
als Antwort auf: barthbradley
Nachricht 5 von 7
anarie
Yes, I’m talking about an image of a sheet of tiles, not an individual tile.
Nachricht 6 von 7
Great! Then the video I posted should answer all your questions.
Nachricht 7 von 7
anarie
Yes, thank you. That was a very helpful video.
