Interior walls wont attach to each other
1 ANTWORT 1
Nachricht 1 von 2
chase.conn72
314 Aufrufe, 1 Antwort
I am trying to connect my walls together but for some reason they wont click together. I just started having this problem and i don't know what i pressed to cause it.
Tags (2)
1 ANTWORT 1
Nachricht 2 von 2
SteveKStafford
als Antwort auf: chase.conn72
When you sketch a wall is the Join Status: Disallow option selected? Look on the options bar. If it is then each wall segment's end point is assigned to Disallow Join. You can select a wall, hover over the endpoint (blue dot) and right click choose Allow Join to reset that.
Steve Stafford
