Is there any way i can create or apply a JPEG. wallpaper design to interior or exterior walls in a Revit model?
If the wallpaper is repetitive then you can create a material and assign the JPG image to its Appearance asset.
If it is a special design for only a certain area then you can use Decal to map the image on a surface.
Good day. If you need a cool wall decoration, I recommend to look at the platform https://fancywalls.eu/wall-decor/peel-stick-removable-wallpaper/. Here you can find a huge number of stylish and high-quality wallpapers that are easy to stick. This is the perfect post.
