Interior Elevations - View Clip Line weight
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
zeulrick
1075 Aufrufe, 6 Antworten
Does anyone know how to change the line weight of the view clip line for Interior elevations. I'd like to make the line weight thicker. Sometimes the clip line doesn't even plot on some views which is annoying. I think that is due to it colliding (overlapping) with certain elements.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: zeulrick
Override Graphics in View By Element.
Nachricht 3 von 7
Nachricht 4 von 7
Nachricht 5 von 7
zeulrick
als Antwort auf: barthbradley
For sure. I have used this option before. I was hoping you'd have another solution to globally make the change instead of changing each individual elevation...
Nachricht 6 von 7
Globally no, but all Existing Interior Elevation could be changed fairly quickly. Select one and then Rightt-Click and Select All Instances in Project and then Save to a Selection Set Filter. Then Add Selection Set Filter to your Elevation Views' View Template.
Nachricht 7 von 7
respresso
From what I see, the most popular way is to make a donut-shaped filled region or mask region, and assign the internal border line style to a certain line style. Then you can adjust the weight for that line style to update for the whole project at once.
