Interior Elevation tag referencing Issue
2 ANTWORTEN 2
Nachricht 1 von 3
elizabetheVCG2P
439 Aufrufe, 2 Antworten
Hello! I have been trying to create an interior elevation view in a project, and when I click the check arrow of an elevation tag, it takes me straight to a 'select view to reference' dialog box, which I do not want.I am actually just trying to get an interior elevation. I do not know how to go about this, please help.  I attached some screen shots.
2 ANTWORTEN 2
Nachricht 2 von 3
hmunsell
als Antwort auf: elizabetheVCG2P
if when the first elevation was placed, it was placed with Reference Other View checked, all the rest of them in that elevation symbol want to do the same thing.
Howard Munsell
Nachricht 3 von 3
kadmonkee
the callout head family is causing this
the family is customized to manage referenced views
select the button in the red circle to open the next window
these nested families control the results
try to import a generic elevation family to compare the two different results
when you select the Interior Elevation tag go into edit type and see what is selected for options
also View Templates and View Types may be in use for that family too
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
