Interior Elevation Tag Missing (Revit 2024)
2 ANTWORTEN 2
Nachricht 1 von 3
ebovill2
129 Aufrufe, 2 Antworten
I don't know if anyone else has experienced this, but my interior elevation tag is missing on my ribbon in Revit 2024. I have tried to reset the ribbon via the user interface, but that has not worked. Does anyone know how to get the interior elevation tag back?
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
theslacollier
als Antwort auf: ebovill2
You can reset any changes made to the interface by deleting the UIState. dat file located at %APPDATA%\Autodesk\Revit\Autodesk Revit <release>. When you delete the file and restart Revit, the ribbon resets to the default condition.
RVT to the max
Nachricht 3 von 3
azad.Nanva
I can't understand your problem,I never seen Interior Elevation Tag,did you mean Spot Elevation or something else?
