Interior elevation tag arrow disappears
5 ANTWORTEN 5
Nachricht 1 von 6
gkwas
815 Aufrufe, 5 Antworten
I have inserted an interior elevation tag into a plan view. When I go the elevation generated by the tag and adjust the crop region of that elevation, the filled arrow of the elevation tag, in the plan disappears. Why?
Thank you,
5 ANTWORTEN 5
Nachricht 2 von 6
SteveKStafford
als Antwort auf: gkwas
Check the annotation crop boundary for the plan view. It will hide any annotation it touches or lies beyond the boundary.
Steve Stafford
Nachricht 3 von 6
gkwas
als Antwort auf: SteveKStafford
That didn't work. I have another interior elevation tag on the same plan, went to that elevation, adjusted the crop region and all is fine. It appears to be that one area. I've tried reloading the tag, and deleting and re-inserting. Nothing has worked.
Nachricht 4 von 6
SteveKStafford
What about ...Hide in Scales Coarser Than... or Discipline. Is a Filter applied to the view/view template?
Steve Stafford
Nachricht 5 von 6
hmunsell
Does the whole arrow disappear or just the fill of the arrow (leaving the outline)?
Howard Munsell
Nachricht 6 von 6
Thank you,
If the crop of your elevation view is outside of the view range of the floor plan view then the elevation mark pointer will not show.
