Hello, I am Prashanth Kumar Goli studying masters in civil engineering (NHRE Program) in Bauhaus Universität Weimar. I have been assigned "INTERFACE BETWEEN BIM AND SIMULATION" project as a part of my curriculum in construction management department. In this project, one of my tasks is to export the geometry data from Revit 3D-model into Excel file which can be later imported in Enterprise Dynamics simulation software. This geometry data includes coordinates in X,Y,Z directions. I have found an add-in namely "Setout point coordinate" which can be used to export coordinates of each part of the Revit 3D-model. But by using "Setout point coordinate" add-in, we should select each element/part of the Revit 3D-model to export the coordinates which are not applicable in higher storied or big structures. So I request you guys to suggest me the process of exporting the whole geometrical data (Coordinates of different parts of Revit model) into excel file which can be applicable for high storied or big structures also. Thanking you regards, Goli.
