Integration Revit x Civil3D
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
1265 Aufrufe, 7 Antworten
What is the best way to import data from Civil3D to REVIT (like corridors and surfaces)?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
You can export file as a DXF 2007 file but before the export you should to isolate all similar elements in a single layers, thin after import file DXF 2007 you can replace the materials from manage, object style importedCAD
Nachricht 3 von 8
And all the elements will be recognized as REVIT elements?
Nachricht 4 von 8
you cant. the only thing you have just you can add materials on it. Revit see it as a link with a geometrical mesh!
Nachricht 5 von 8
Did you guys ever try to use any XML integration? It is a painfull to model everything again using floors, masses, etc..
Nachricht 6 von 8
Viveka_CD
Hi @Anonymous
Please see Corridor Modeling Workflow and how you can export several types of data
Also, take a look at 4 ways to coordinate data between Revit and Civil3D
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Nachricht 7 von 8
als Antwort auf: Viveka_CD
It is still not the best workflow I guess. But It is the best we have for now. I'll accept that as a solution.
Thank you!
Nachricht 8 von 8
Viveka_CD
Hi @Anonymous
Thanks for accepting the solution. I see your point regarding the workflow.
If you can share a file, we can dive deep and see how to simplify it up for an optimal workflow.
Let me know and I can share a  private folder with you.
