Insulation-Wall Detail to Window
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
Revitician
2505 Aufrufe, 7 Antworten
Hello, I need to achieve the following detail attached. Insulation makes a 90 degree and joins the window fixed to a wall.
Which is the most suitable way? Any thoughts very appreciated.
7 ANTWORTEN 7
Nachricht 2 von 8
constantin.stroescu
als Antwort auf: Revitician
You can obtain this , by using Wraping at Inserts > Both or only Exterior and extending Wraps to the Thermal/Air Layer
Constantin Stroescu
BIM Manager AGD
Your Name
Nachricht 3 von 8
Revitician
als Antwort auf: constantin.stroescu
@constantin.stroescu
Constantin, thanks for your message.
In the wall that you are showing, structural RC and insulation goes together. Even though, in previous posts I was strongly recommended to separate structural walls and architectural. I agree with separating these as when I was using an structural+architectural wall I had several problem with joints, etc..
I woul appreciate if you could advice on this, as I have it in two separate walls.
Nachricht 4 von 8
Revitician
my second question is, is it possible to have half thickness of insulation or less when it wraps to the window ( as we normally do in construction)
Nachricht 5 von 8
RDAOU
@Revitician
Looking at your other post between MPwu and Autodesk's Macho man and  myself ...I have to admit that you got really confused.
Walls consist of layers; irrespective if they are structural or architectural...In principle; the CORE of the wall withholds it's the structural properties.
That being said;
  1. if you use either or of those types (A or S); your modeled wall will have  similar layers (Structure , Substrate , Thermal/Air Layer , Membrane , Finish1, Finish2)
  2. An architectural walls can still be defined as structural with analytical properties. All you have to do is
    • "select that wall" & "check the designated box in the Properties Pallets"
    • Edit Properties > Structure > Make sure the structural layer in the core is checked as Structural Material
  3. Structural "layers" can still be assigned outside the core (as long as they respect the placement order of layers [1] to [5]. However; Revit will consider only the layer inside the core and which is checked as structural material to be the load bearing element of the wall.
  4. User can only check 1 layer as structural material and it has to be in the CORE (A Layer placed outside the core boundaries, even if it uses a Structural Layer) are not deemed structural elements and cannot be checked as structural material
Recommendation: (more than strongly)
You are in the process of learning how to use Revit... Stick to one type of walls (preferably Architectural). You shouldn't not start investigating Structural Walls (those placed using Wall: Structural) before you
  1. understand everything about Architectural walls and how they function
  2. Understand the properties of layers and how to use layers in different walls
On your problem with joints; if you stick to the above you wont have issues with joints....and when the time comes where you are good to go with structural walls; you will find out that there is no issue with joints either. At the moment you are having that issue because you are using them arbitrarily and you are taking advice from several source (which is not bad) but can get confusing when those different sources do not know your Revit background..
Same like on your other post on Wall chamfers at windows... Chris thought you were talking about horizontal sweeps along the skirting (I did too at first). So it is pretty much hard to convey the proper advice if one isn't aware of what is happening on your side of the screen
Revit wraps the Insulation Layer you have set in it's structure...The thickness of that layer is not  variable.
You can detail it separately; but to make the wrap half thickness in the wall built-up layers it is not possible
Nachricht 6 von 8
constantin.stroescu
In such case I use two layers of thermal insulation ,one over the other and I wrap only the exterior layer...
Constantin Stroescu
BIM Manager AGD
Your Name
Nachricht 7 von 8
Revitician
als Antwort auf: RDAOU
@RDAOU
@mpwuzhere more than strongly recommended the following, so that's why I had to do a little bit of research/try-error-ask-learn proccess on the issue:
Recommend keeping structural wall types separate from interior types.  They will join a lot better.  So furring (the insulation) would be a separate type than the concrete wall.
Thanks again
Nachricht 8 von 8
Hi Mate,
For those who are interested in conducting a wall insulation treatment project for under a £1000, pls visit my website.
http://www.insulationsydney.com.au/
If this is in breach of forum rules, mods pls delete or move.
Rail Community
