pls see attached - pointer #10 to mineral wool packing a 5mm insulation line (batting)
this has just started happening on my 2015.... only on drafting views? any ideas. its not the end of the world as we know it - just curious. and can i have the 'original' back pls......
Gelöst! Gehe zur Lösung
Gelöst von loboarch. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
The whole thing look weird. What the heck happened to the keynotes as well? If it was a model view then I would say check the distance from the model to the origin coordinates but you said drafting views so I have no clue.
This is the kind of "breakdown" you see when working really far from the origin. I would check to see if something like that has happened.
