Instance Wall Tag
Instance Wall Tag
KraiggC
Instance Wall Tag
KraiggC
Is it possible to create, or is there one already, a tag that reads the "Mark" Instance Parameter in a wall? I've tried creating and editing wall tags and I can't seem to find the Mark parameter in the Label menu. Thank you in advance for your help.
EDIT: I'm either blind or exhausted, the Mark parameter was there the whole time. Could a Moderator please delete this post. I couldn't see the option to do so myself. Thank you!
Sometimes it is classified under TYPE MARK instead of MARK, also, if you look in the properties browser, you should be able to type it in the identity data and it should show up once you tag it. Another solution that could also allow you to customize tags is the keynote system. I find this to be the most convenient way to tag whatever i want without being restricted to a specific parameter.
