Help me, please - before i'm going crazy! ![]()
On my first "sheet", an instance parameter appears in my properties... (Picture attached).
I can't remove it - I think I have tried everything, but apparently not enough.
Thanks for your help!
Kind regards Morten
Look here:
Manage tab>Project Parameters>Sheets...……….then use Remove to delete the parameter.
I have tried that, but i can't find the parameter and delete it.
I can make a new "Text"-parameter. And delete it again.
But it seems like, i can't delete this, old parameter....
Are you saying "Virker Det" is not listed under Project Parameters?
Look in the Family itself.
-Confirm if it is in the Project Parameters List--assuming that is the one in your snapshot?
-Check Shared Parameters also
-Open Titleblock family and see if you can find/delete it
Text Parameter "Virker Det" is not listed under Manage => Project Parameters.
I've checked the Shared Parameters as well, with no luck!
It seems like it's some sort of "Ghost Parameter".
I have checked the family as well, no luck either.
It must be there some where, big question is; Where?
It appears to be a Text Parameter. Can you post your Title Block Family
so we can take a look?
I think I have tried everything. (For that simple fact; I just want to delete this F..... Text Parameter.)
Any way, I did it the easy way - deleted the old sheet - and made a new one. The parameter is now gone!
The story about the "Ghost Parameter" is for now on, still a mystery. ![]()
Thanks for your help.
