Instance Parameter in Family problem.
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
hn_aec_05
558 Aufrufe, 3 Antworten
Hi everyone,
I have struggle when creating this share parameter.
In this family, I create shared parameter "4d name" instance, but it still appear in dialog, not in red circle area as image.
I reset Revit and try to do again but the same result.
Can anyone help me with this problem. Many thanks to you.
Sorry for my bad English.
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: hn_aec_05
@hn_aec_05
You are still in the Family Editor...When you load it into the Project, the instance parameter will appear in the Properties Palette
Nachricht 3 von 4
hn_aec_05
als Antwort auf: RDAOU
Thanks so much for your advice.
So in family, we can't make instance parameter for each nested family right ?
Cause I want to specify each component in this family.
Nachricht 4 von 4
RDAOU
@hn_aec_05
Yes you can create in the parent/host family as much instance parameters as you wish and associate the nested family parameters to those instance parameter!
When the parameter is created in the family (host or child), it will only appear in the Type properties of that particular family...the instance parameter will only show/appear in the properties palette once it is loaded into the project or nested into another family
ie:
  1. the instance parameter created in the nested child will appear in the palette of the parent/host ...in order for you to be able to select and associate it to a parameter in the parent/host family
  2. the instance parameter created in the parent/host family will only show in the palette when it is loaded into the project
