Instance Parameter Adaptive Family
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
FRAN1972
446 Aufrufe, 2 Antworten
Morning,
I am trying make an adaptive family of two surface with a common edge. Ever instance have a different angle between the surfaces and i want to get the differentes values of that angle. I made a share parameter and i created the angle  dimmension. Finally I join the shared parameter for instance to the dimmension.
The problem is that the value of the parameter doesn´t refresh, always has the same value spite of the angle of ever instances be different.
Somebody could me tell what happen?
Regards.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: FRAN1972
Set it as a reporting parameter.
Nachricht 3 von 3
FRAN1972
als Antwort auf: ToanDN
Thanks a lot.
Regards
